跳转到主内容
Compaq Presario CQ62-215dx RAM Replacement
你所需要的
  1. Compaq Presario CQ62-215dx RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • lay the laptop upside down.
  2. Compaq Presario CQ62-215dx RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pushing the lock to the left and lifting the battery from its socket.
  3. Compaq Presario CQ62-215dx RAM Replacement: 步骤 3 中的图像 1,1
    • Once the battery is out, locate a panel that is underneath the battery compartment and unscrew the three 3mm screws with a Philips screwdriver.
  4. Compaq Presario CQ62-215dx RAM Replacement: 步骤 4 中的图像 1,1
    • Once removed, you should have something like in this picture. Locate the current RAM.
  5. Compaq Presario CQ62-215dx RAM Replacement: 步骤 5 中的图像 1,1
    • To remove the RAM, start by lifting up the first card. Grab each side of the card with two fingers as shown in the picture and pull gently until it is removed from its slot.
  6. Compaq Presario CQ62-215dx RAM Replacement: 步骤 6 中的图像 1,1
    • Insert your new RAM replacement into the slot where the old one was removed. Push until you hear a small click.
  7. Compaq Presario CQ62-215dx RAM Replacement: 步骤 7 中的图像 1,1
    • Push the card downward into the compartment until you hear another clicking sound.
结论
另外一个人完成了本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 771
