跳转到主内容
Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
你所需要的
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 步骤 3 中的图像 1,1
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 步骤 5 中的图像 1,1
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 步骤 6 中的图像 1,1
    • This is where you detach your old hard drive and replace with the new component.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 314
