跳转到主内容
Compaq Presario CQ62 Hard Drive Replacement
你所需要的
  1. Compaq Presario CQ62  Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Compaq Presario CQ62  Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,2 Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Loosen the two M2.5x3 mm Phillips screws securing the hard drive cover.
  3. Compaq Presario CQ62  Hard Drive Replacement: 步骤 3 中的图像 1,1
    • On the same side as the two screws, there should now be an opening to lift off the cover. Using a plastic opening tool, sightly lift the case up to remove it.
  4. Compaq Presario CQ62  Hard Drive Replacement: 步骤 4 中的图像 1,2 Compaq Presario CQ62  Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the three M2.5x5 mm Phillips screws securing the hard drive assembly.
  5. Compaq Presario CQ62  Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Our laptop did not have a hard drive, so it is not included in the photo.
    • To remove the hard drive, detach it from the the hard drive connector. You can do this by pulling it gently with your hands.
结论
另外一个人完成了本指南。
Roth Marcelin
于10/06/16注册
726 声望
创作了6篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 3,047
