跳转到主内容
Compaq Presario CQ60-211DX Display Assembly Replacement
你所需要的
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 2 中的图像 1,2 Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 3 中的图像 1,2 Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
结论
Garrett Carter
于09/21/18注册
471 声望
创作了4篇指南
2条评论
My laptop model Compaq predario cq61 h
Rashid 007 - 回复
Computer on but display light of computer is running
Rashid 007 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 26
总计 1,104
