跳转到主内容
Compaq Evo N1000v Rear Fan Replacement
你所需要的
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: 步骤 1 中的图像 1,1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: 步骤 2 中的图像 1,2 Compaq Evo N1000v Rear Fan Replacement: 步骤 2 中的图像 2,2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: 步骤 3 中的图像 1,1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: 步骤 4 中的图像 1,1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: 步骤 5 中的图像 1,1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: 步骤 6 中的图像 1,1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: 步骤 7 中的图像 1,1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: 步骤 10 中的图像 1,1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new rear fan.
结论
另外一个人完成了本指南。
ryan
于03/12/14注册
470 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S2G1
3 名成员
创作了4篇指南
一条评论
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 398
