跳转到主内容
Compaq Evo N1000v Heat Sink Replacement
你所需要的
  1. Compaq Evo N1000v Heat Sink Replacement, LED Cover: 步骤 1 中的图像 1,1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Heat Sink Replacement: 步骤 5 中的图像 1,1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Heat Sink Replacement: 步骤 6 中的图像 1,1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Heat Sink Replacement: 步骤 7 中的图像 1,1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Heat Sink Replacement: 步骤 8 中的图像 1,2 Compaq Evo N1000v Heat Sink Replacement: 步骤 8 中的图像 2,2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Heat Sink Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Heat Sink Replacement: 步骤 10 中的图像 1,1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Heat Sink Replacement: 步骤 11 中的图像 1,1
    • Remove the keyboard.
  12. Compaq Evo N1000v Heat Sink Replacement, Heat Sink: 步骤 12 中的图像 1,1
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Heat Sink Replacement: 步骤 13 中的图像 1,1
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Heat Sink Replacement: 步骤 14 中的图像 1,1
    • Pull the the heat sink up and out of the computer.
结论
2等其他人完成本指南。
kim
于04/14/10注册
59 声望
创作了3篇指南
团队
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G74
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 4,028
