跳转到主内容
Commodore 64 VIC Chip Replacement
你所需要的
  1. Commodore 64 VIC Chip Replacement, Removing screws: 步骤 1 中的图像 1,3 Commodore 64 VIC Chip Replacement, Removing screws: 步骤 1 中的图像 2,3 Commodore 64 VIC Chip Replacement, Removing screws: 步骤 1 中的图像 3,3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 VIC Chip Replacement, Opening: 步骤 2 中的图像 1,2 Commodore 64 VIC Chip Replacement, Opening: 步骤 2 中的图像 2,2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: 步骤 3 中的图像 1,2 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: 步骤 3 中的图像 2,2
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: 步骤 4 中的图像 1,2 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: 步骤 4 中的图像 2,2
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: 步骤 5 中的图像 1,2 Commodore 64 VIC Chip Replacement, Removing the Chip: 步骤 5 中的图像 2,2
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
结论
2等其他人完成本指南。
Silvanus Clarke
于09/26/14注册
677 声望
创作了5篇指南
团队
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G6
4 名成员
创作了15篇指南
1指南评论
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 34
总计 5,151
