跳转到主内容
加入维修社区 - 创建账户
Commodore 64 Removing the Shift-Lock Key
你所需要的
  1. Commodore 64 Removing the Shift-Lock Key, Removing the screws: 步骤 1 中的图像 1,3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 步骤 1 中的图像 2,3 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 步骤 1 中的图像 3,3
    • 1. Remove three 6.75mm ph2 screw heads from the casing.
    询问修复机器人
  2. Commodore 64 Removing the Shift-Lock Key, Opening the Case: 步骤 2 中的图像 1,1
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
    询问修复机器人
  3. Commodore 64 Removing the Shift-Lock Key, Removing screws (continued): 步骤 3 中的图像 1,1
    • 3. Remove eight 6.75 mm ph2 screw heads to detach the keyboard face from the front casing. (Two remaining screws on the right side.)
    询问修复机器人
  4. Commodore 64 Removing the Shift-Lock Key, Removing Screws (continued): 步骤 4 中的图像 1,1
    • 4. Remove twenty-three 3.38 mm ph2 screw heads from the back of the keyboard facing
    询问修复机器人
  5. Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 步骤 5 中的图像 1,3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 步骤 5 中的图像 2,3 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 步骤 5 中的图像 3,3
    • 5. Detach the multi-colored wire bundles connected to the motherboard
    询问修复机器人
  6. Commodore 64 Removing the Shift-Lock Key, Cutting the Wires: 步骤 6 中的图像 1,1
    • 6. Next, carefully cut the two small wires which are connected from the Shift/Lock key to the keyboard.
    询问修复机器人
  7. Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 步骤 7 中的图像 1,2 Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 步骤 7 中的图像 2,2
    • 7. Turn the keyboard down on its face and push the shift lock key out from the back of the keyboard.
    询问修复机器人
  8. Commodore 64 Removing the Shift-Lock Key, Removal of circuit component from shift-lock key (optional): 步骤 8 中的图像 1,1
    • 8. You can remove the circuit component (gray piece attached to the shift lock key spring) by pulling back slightly on its clip and pulling it apart from the shift lock key button.
    • * Take off the shift key button from the spring by using any Philips screwdriver to pry it off from the spring.
    询问修复机器人
结论
5等其他人完成本指南。
团队
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G6
4 名成员
创作了15篇指南
1指南评论
You should desoder the shift lock wires. Not cut them :(
Darek Greenly - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 55
总计 2,925
