跳转到主内容
加入维修社区 - 创建账户
Commodore 64 3AG fuse Replacement
你所需要的
  1. Commodore 64 3AG fuse Replacement, Removing screws: 步骤 1 中的图像 1,3 Commodore 64 3AG fuse Replacement, Removing screws: 步骤 1 中的图像 2,3 Commodore 64 3AG fuse Replacement, Removing screws: 步骤 1 中的图像 3,3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
    询问修复机器人
  2. Commodore 64 3AG fuse Replacement, Opening: 步骤 2 中的图像 1,2 Commodore 64 3AG fuse Replacement, Opening: 步骤 2 中的图像 2,2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: 步骤 3 中的图像 1,2 Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: 步骤 3 中的图像 2,2
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
    • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
    询问修复机器人
  4. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: 步骤 4 中的图像 1,1
    • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
    询问修复机器人
  5. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: 步骤 5 中的图像 1,2 Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: 步骤 5 中的图像 2,2
    • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
    • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
    询问修复机器人
结论
4等其他人完成本指南。
团队
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G6
4 名成员
创作了15篇指南
2指南评论
The fuse is 1.5 Amp, not 3
JC Andy - 回复 分享
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
Toon Konings - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 81
总计 4,757
