跳转到主内容
Comment forcer le redémarrage de l'iPhone 8 Plus
你所需要的
  1. Comment forcer le redémarrage de l'iPhone 8 Plus, Comment forcer le redémarrage de l'iPhone 8 Plus: 步骤 1 中的图像 1,1
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    The picture makes it look like you need to start this process with the phone turned on already, but I think you need to start with it powered off - that’s the only way that long-pressing the power button in Step 2 causes the Apple logo to appear.
    Owen Edwards - 回复
    For an iPhone 8, step #3 is to press and hold the right-side button. Continue holding the button down until the apple logo appears, then release.
    sjf - 回复
    what if the apple logo appears but nothing else happens. it just keeps showing the logo.
    LeRoyal - 回复
  2. Comment forcer le redémarrage de l'iPhone 8 Plus: 步骤 2 中的图像 1,1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    How can i have apple id and password to fix my phone
    Mhreteab Adresom - 回复
终点
65等其他人完成本指南。
2条评论
What if my side power button doesn’t work?
Alex Busnelli - 回复
Are there any preconditions? Like should the iPhone be ON before step 1?
Are there any side effects? Like resetting momory, settings, etc?
Eric Bolinger - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 114
过去 30 天: 593
总计 39,896
