跳转到主内容
Comfort Zone CZ6C Fan Blades Replacement
你所需要的
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 步骤 1 中的图像 1,3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 步骤 1 中的图像 2,3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: 步骤 1 中的图像 3,3
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: 步骤 2 中的图像 1,2 Comfort Zone CZ6C Fan Blades Replacement: 步骤 2 中的图像 2,2
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G5
4 名成员
创作了5篇指南
2条评论
Where does one buy the replacement blades?
Frank Gould - 回复
where does one buy the replacement blades??
Luis Marrero - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 5,841
