跳转到主内容
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
你所需要的
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: 步骤 1 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 2 中的图像 1,1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 3 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 3 中的图像 2,2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 4 中的图像 1,3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 4 中的图像 2,3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 4 中的图像 3,3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: 步骤 5 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: 步骤 5 中的图像 2,2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 6 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 6 中的图像 2,2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 7 中的图像 1,3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 7 中的图像 2,3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: 步骤 7 中的图像 3,3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
结论
Mathew Merrick
于09/17/18注册
169 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 595
