跳转到主内容
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
你所需要的
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 步骤 1 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 步骤 1 中的图像 2,2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 2 中的图像 1,1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 3 中的图像 1,2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 3 中的图像 2,2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 4 中的图像 1,3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 4 中的图像 2,3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 步骤 4 中的图像 3,3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
结论
Sean
于09/17/18注册
265 声望
创作了2篇指南
团队
一条评论
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 93
总计 4,889
