跳转到主内容
ColecoVision Motherboard Replacement
你所需要的
  1. ColecoVision Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. ColecoVision Motherboard Replacement: 步骤 2 中的图像 1,2 ColecoVision Motherboard Replacement: 步骤 2 中的图像 2,2
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. ColecoVision Motherboard Replacement: 步骤 3 中的图像 1,2 ColecoVision Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. ColecoVision Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
结论
另外一个人完成了本指南。
Krystalina
于10/24/18注册
121 声望
撰写一个指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 的会员
UWT-ROSE-F18S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 29
总计 1,584
