跳转到主内容
加入维修社区 - 创建账户
Coin Display Case Glass Attachment
你所需要的
  1. Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: 步骤 1 中的图像 1,2 Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: 步骤 1 中的图像 2,2
    • Clean the display case thoroughly with glass cleaner and a paper towel.
  2. Coin Display Case Glass Attachment: 步骤 2 中的图像 1,1
    • Gently pry the glass away from the glue on the frame. Be careful not to shatter the glass.
  3. Coin Display Case Glass Attachment: 步骤 3 中的图像 1,1
    • Apply a thin, solid line of a strong adhesive, such as Gorilla Glue, to the entire inner border of the display case where the glass attaches.
  4. Coin Display Case Glass Attachment: 步骤 4 中的图像 1,2 Coin Display Case Glass Attachment: 步骤 4 中的图像 2,2
    • Gently, but firmly, press the glass back into the felt lining. Run your finger with firm pressure along the entire lining of the glass two times.
  5. Coin Display Case Glass Attachment: 步骤 5 中的图像 1,1
    • Allow the glue to set for 2-4 hours for the strongest bond.
    • Keep the case in the upright position while the glue sets.
    • Do not close or shut the case during the drying/setting process.
结论
Allow the glass and glue to bond for at least 6 hours before using the case.
Jesse Norris
于02/08/16注册
113 声望
撰写一个指南
团队
Pasco Hernando, Team 5-2, Prince Winter 2016 Pasco Hernando, Team 5-2, Prince Winter 2016 的会员
PHSC-PRINCE-W16S5G2
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 31
总计 1,345
