跳转到主内容
Coby Kyros MID9742 Screen Replacement
你所需要的
  1. Coby Kyros MID9742 Screen Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Screen Replacement: 步骤 2 中的图像 1,1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Screen Replacement: 步骤 3 中的图像 1,1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
  5. Coby Kyros MID9742 Screen Replacement: 步骤 5 中的图像 1,1
    • Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
    • Gently pull the ribbon cable from the port.
  6. Coby Kyros MID9742 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the screen from the device.
结论
2等其他人完成本指南。
Ian Swett
于03/11/15注册
597 声望
创作了5篇指南
团队
Colorado Springs, Team 5-3, Panko Spring 2015 Colorado Springs, Team 5-3, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G3
3 名成员
创作了12篇指南
3条评论
Is the flex cable detachable from the LCD
maynell Rodrigues - 回复
Do u have the display flex cable
how much does it cost for screen
jnapps mu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,084
