跳转到主内容
Coby Kyros MID9042 Camera Replacement
你所需要的
  1. Coby Kyros MID9042 Camera Replacement, Camera: 步骤 1 中的图像 1,3 Coby Kyros MID9042 Camera Replacement, Camera: 步骤 1 中的图像 2,3 Coby Kyros MID9042 Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Before removing anything from the tablet, make sure to power off the device.
    • After powering off device, remove the anti-slip pads from all 4 corners on the back of the device.
    • Once slip pads are removed, proceed to unscrewing the four 3.2 mm Phillips #0 screws from the back cover.
  2. Coby Kyros MID9042 Camera Replacement: 步骤 2 中的图像 1,3 Coby Kyros MID9042 Camera Replacement: 步骤 2 中的图像 2,3 Coby Kyros MID9042 Camera Replacement: 步骤 2 中的图像 3,3
    • When removing the back cover, be careful not to break the inner plastic tabs.
    • Use the blue plastic opening tool to wedge the back cover apart from the front.
    • Once the edges are wedged apart, use hands to lift up the back of the tablet.
  3. Coby Kyros MID9042 Camera Replacement: 步骤 3 中的图像 1,3 Coby Kyros MID9042 Camera Replacement: 步骤 3 中的图像 2,3 Coby Kyros MID9042 Camera Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the gold flap and use tweezers to lift the flap up.
    • Use a second pair of tweezers to pull the gold tab connected to the camera out of the circuit board.
    • Once the tab is removed from the circuit board, pull the camera out of the tablet.
    • Caution! Be sure to avoid pulling the gold flap off the the circuit board.
结论
团队
UMass Dartmouth, Team 2-6, Shastany Spring 2015 UMass Dartmouth, Team 2-6, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S2G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 298
