跳转到主内容
加入维修社区 - 创建账户
Coby Kyros MID7125 Speaker Replacement
你所需要的
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: 步骤 2 中的图像 1,1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: 步骤 4 中的图像 1,1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: 步骤 6 中的图像 1,1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
结论
Nicole Connelly
于10/20/16注册
1 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 14
总计 246
