当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Press the eject button to view the laser inside.
Using the blue plastic tool and the tweezers, remove the ribbon cable.
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
Pry the top of the device open from the right side where the buttons are located.
When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
The location of the springs are circled.
Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
Remove the rails from the disk reader.
Once the top rail is removed, the white gear will come off and under it will be one of the springs.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
