跳转到主内容
Coby DVD209 DVD Laser Reader Replacement
你所需要的
  1. Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 1,3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 2,3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 DVD Laser Reader Replacement: 步骤 2 中的图像 1,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 2 中的图像 2,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 2 中的图像 3,3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 DVD Laser Reader Replacement: 步骤 3 中的图像 1,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 3 中的图像 2,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 3 中的图像 3,3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: 步骤 4 中的图像 1,2 Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: 步骤 4 中的图像 2,2
    • Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
    • Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
  5. Coby DVD209 DVD Laser Reader Replacement: 步骤 5 中的图像 1,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 5 中的图像 2,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 5 中的图像 3,3
    • There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
    • The location of the springs are circled.
    • Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
    • The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
  6. Coby DVD209 DVD Laser Reader Replacement: 步骤 6 中的图像 1,2 Coby DVD209 DVD Laser Reader Replacement: 步骤 6 中的图像 2,2
    • Be careful not to lose the spring at the top of the laser.
    • Lift the laser assembly out of the fixture.
  7. Coby DVD209 DVD Laser Reader Replacement: 步骤 7 中的图像 1,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 7 中的图像 2,3 Coby DVD209 DVD Laser Reader Replacement: 步骤 7 中的图像 3,3
    • Remove the rails from the disk reader.
    • Once the top rail is removed, the white gear will come off and under it will be one of the springs.
结论
另外一个人完成了本指南。
Yufay Chow
于01/23/12注册
92 声望
创作了4篇指南
团队
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G36
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 858
