跳转到主内容
Coby DVD209 Circuitboards Replacement
你所需要的
  1. Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 1,3 Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 2,3 Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 3,3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuitboards Replacement: 步骤 2 中的图像 1,3 Coby DVD209 Circuitboards Replacement: 步骤 2 中的图像 2,3 Coby DVD209 Circuitboards Replacement: 步骤 2 中的图像 3,3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuitboards Replacement: 步骤 3 中的图像 1,3 Coby DVD209 Circuitboards Replacement: 步骤 3 中的图像 2,3 Coby DVD209 Circuitboards Replacement: 步骤 3 中的图像 3,3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 1,3 Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 2,3 Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 3,3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
  5. Coby DVD209 Circuitboards Replacement, Circuitboards: 步骤 5 中的图像 1,3 Coby DVD209 Circuitboards Replacement, Circuitboards: 步骤 5 中的图像 2,3 Coby DVD209 Circuitboards Replacement, Circuitboards: 步骤 5 中的图像 3,3
    • Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously.
    • Lift the power port out of the its slot.
  6. Coby DVD209 Circuitboards Replacement: 步骤 6 中的图像 1,3 Coby DVD209 Circuitboards Replacement: 步骤 6 中的图像 2,3 Coby DVD209 Circuitboards Replacement: 步骤 6 中的图像 3,3
    • Remove the four 5mm screws circled in red.
    • Place the blue plastic tool opener underneath the circuitboard and lift up gently.
  7. Coby DVD209 Circuitboards Replacement: 步骤 7 中的图像 1,3 Coby DVD209 Circuitboards Replacement: 步骤 7 中的图像 2,3 Coby DVD209 Circuitboards Replacement: 步骤 7 中的图像 3,3
    • Unplug the two, 3-pin ribbon cables, which are attached to the circuitboard.
    • For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device.
  8. Coby DVD209 Circuitboards Replacement: 步骤 8 中的图像 1,3 Coby DVD209 Circuitboards Replacement: 步骤 8 中的图像 2,3 Coby DVD209 Circuitboards Replacement: 步骤 8 中的图像 3,3
    • Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports.
结论
另外一个人完成了本指南。
Kyle VanAllen
于01/20/12注册
70 声望
创作了2篇指南
团队
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G36
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 414
