跳转到主内容
Coby DVD209 4-Pin Ribbon Cable Replacement
你所需要的
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 1,3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 2,3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 2 中的图像 1,3 Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 2 中的图像 2,3 Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 2 中的图像 3,3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 3 中的图像 1,3 Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 3 中的图像 2,3 Coby DVD209 4-Pin Ribbon Cable Replacement: 步骤 3 中的图像 3,3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 1,3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 2,3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: 步骤 4 中的图像 3,3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
结论
另外一个人完成了本指南。
Yufay Chow
于01/23/12注册
92 声望
创作了4篇指南
团队
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G36
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,052
