当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the power switch, the leftmost knob, counterclockwise to off.
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Unscrew the securing cap counterclockwise from the antenna connector.
Gently pull the antenna cable to remove it from the back of the radio.
Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
Gently unplug the microphone plug.
Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
Gently life and remove the top cover.
Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
Carefully flip the radio over.
Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
Gently lift and remove the case cover.
取消:我没有完成这个指南。
2等其他人完成本指南。
与5其他贡献者
于10/20/13注册
267 声望
创作了2篇指南
徽章: 11
+ 8更多徽章
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 1,646
