跳转到主内容
Cobra 29 LTD Classic Outer Cover Replacement
你所需要的
  1. Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: 步骤 1 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement, Power Cable: 步骤 1 中的图像 2,2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 2 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 2 中的图像 2,2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: 步骤 3 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement, Antenna Cable: 步骤 3 中的图像 2,2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 4 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 4 中的图像 2,2
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Outer Cover Replacement, Microphone: 步骤 5 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement, Microphone: 步骤 5 中的图像 2,2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 6 中的图像 1,1
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: 步骤 7 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement, Outer Cover: 步骤 7 中的图像 2,2
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 8 中的图像 1,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 8 中的图像 2,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 8 中的图像 3,3
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 9 中的图像 1,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 9 中的图像 2,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 9 中的图像 3,3
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 10 中的图像 1,2 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 10 中的图像 2,2
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Outer Cover Replacement: 步骤 11 中的图像 1,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 11 中的图像 2,3 Cobra 29 LTD Classic Outer Cover Replacement: 步骤 11 中的图像 3,3
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
结论
2等其他人完成本指南。
Chase
于10/20/13注册
267 声望
创作了2篇指南
团队
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,633
