跳转到主内容
修复你的物品
维修的权力
商店
简介
Whether your knobs are broken or you want to put a decorative sticker on your front panel, sometimes you need to get the knobs off of your radio. This guide will instruct you on how to use plastic opening tools to safely remove the knobs.
配件
没有特定配件。
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. Gently unplug the microphone plug.
    • Gently unplug the microphone plug.
  6. Gently turn the middle four knobs counter-clockwise until they no longer move.
    • Gently turn the middle four knobs counter-clockwise until they no longer move.
    • The middle four knobs are held in place by friction and do not have a way to keep them in the correct position. When reassembling the middle four knobs, make sure to line up the mark on the knob with the left-most mark on the front panel.
  7. Insert two plastic opening tools behind the tuning knob. With some force, pry the knob off of the radio.
    • Insert two plastic opening tools behind the tuning knob.
    • With some force, pry the knob off of the radio.
    • Two opening tools are needed so that you don't break the knob or connector by applying uneven force.
  8. Repeat the above procedure with the remaining knobs. The final knob will have a power knob on the end of it. When reassembling, put the power knob on last. The final knob will have a power knob on the end of it. When reassembling, put the power knob on last.
    • Repeat the above procedure with the remaining knobs.
    • The final knob will have a power knob on the end of it. When reassembling, put the power knob on last.
结论
To reassemble your device, align the buttons and push them on.
另外一个人完成了本指南。
Matt Williams
于2013年10月20日注册
133 信誉积分
撰写一个指南
团队
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 39
总计 3,774
