当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
Carefully flip the radio over.
De-solder the red wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
During reassembly you will need to resolder the components back together.
The wire may still be hot, so let it sit for 30 seconds before continuing.
Remove the red wire and make sure it is out of the way.
De-solder the white wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
Pull the white wire out and set it aside.
The cover with the internal speaker should be completely separate from the device at this point.
Unscrew the four 6.0 mm screws counterclockwise that surround the grate with a #1 Phillips Screwdriver.
When removing the four screws, the speaker may detach before you flip over the cover.
Flip the cover over and remove the speaker from the cover.
The nuts should remain attached to the speaker by lock-tight glue, however some might fall off.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
