跳转到主内容
Cobra 29 LTD Classic Internal Speaker Replacement
你所需要的
  1. Cobra 29 LTD Classic Internal Speaker Replacement, Power Cable: 步骤 1 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement, Power Cable: 步骤 1 中的图像 2,2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 2 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 2 中的图像 2,2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Internal Speaker Replacement, Antenna Cable: 步骤 3 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement, Antenna Cable: 步骤 3 中的图像 2,2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 4 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Internal Speaker Replacement, Microphone: 步骤 5 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement, Microphone: 步骤 5 中的图像 2,2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Internal Speaker Replacement, Outer Cover: 步骤 7 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement, Outer Cover: 步骤 7 中的图像 2,2
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 8 中的图像 1,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 8 中的图像 2,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 8 中的图像 3,3
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 9 中的图像 1,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 9 中的图像 2,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 9 中的图像 3,3
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 10 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 10 中的图像 2,2
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 11 中的图像 1,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 11 中的图像 2,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 11 中的图像 3,3
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
  12. Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: 步骤 12 中的图像 1,3 Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: 步骤 12 中的图像 2,3 Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: 步骤 12 中的图像 3,3
    • De-solder the red wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
    • During reassembly you will need to resolder the components back together.
  13. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 13 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 13 中的图像 2,2
    • The wire may still be hot, so let it sit for 30 seconds before continuing.
    • Remove the red wire and make sure it is out of the way.
  14. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 14 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 14 中的图像 2,2
    • De-solder the white wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
  15. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 15 中的图像 1,1
    • Pull the white wire out and set it aside.
    • The cover with the internal speaker should be completely separate from the device at this point.
  16. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 16 中的图像 1,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 16 中的图像 2,3 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 16 中的图像 3,3
    • Gently flip the cover over.
    • The main body should be set aside on a non-static and flat surface. The cover with the internal speaker should now be by itself.
  17. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 17 中的图像 1,1
    • Unscrew the four 6.0 mm screws counterclockwise that surround the grate with a #1 Phillips Screwdriver.
    • When removing the four screws, the speaker may detach before you flip over the cover.
  18. Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 18 中的图像 1,2 Cobra 29 LTD Classic Internal Speaker Replacement: 步骤 18 中的图像 2,2
    • Flip the cover over and remove the speaker from the cover.
    • The nuts should remain attached to the speaker by lock-tight glue, however some might fall off.
结论
2等其他人完成本指南。
Noah Negrey
于10/13/13注册
349 声望
创作了2篇指南
团队
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
一条评论
Where can I buy that speaker from I can't find one anywhere online
Henry Guitron - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 5,101
