跳转到主内容
Cobra 29 LTD Classic Antenna Cable Replacement
  1. Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: 步骤 1 中的图像 1,2 Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: 步骤 1 中的图像 2,2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Antenna Cable Replacement: 步骤 2 中的图像 1,2 Cobra 29 LTD Classic Antenna Cable Replacement: 步骤 2 中的图像 2,2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: 步骤 3 中的图像 1,2 Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: 步骤 3 中的图像 2,2
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Antenna Cable Replacement: 步骤 4 中的图像 1,2 Cobra 29 LTD Classic Antenna Cable Replacement: 步骤 4 中的图像 2,2
    • Gently pull the antenna cable to remove it from the back of the radio.
结论
danperoni
于10/18/13注册
503 声望
创作了4篇指南
团队
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
一条评论
I dislike that kind of antenna plug. To easy to put together wrong. Better to find a pl259 plug that gets soldered. YouTube must have a video on it somewhere.
rrmanning06 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 2,239
