跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
The antenna cable connects the antenna to the antenna connector.
工具
没有特定工具。
配件
没有特定配件。
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Unscrew the securing cap counterclockwise from the antenna connector. Unscrew the securing cap counterclockwise from the antenna connector.
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Gently pull the antenna cable to remove it from the back of the radio. Gently pull the antenna cable to remove it from the back of the radio.
    • Gently pull the antenna cable to remove it from the back of the radio.
结论
danperoni
于2013年10月18日注册
485 信誉积分
创作了4篇指南
团队
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G37
4 名成员
创作了9篇指南
I dislike that kind of antenna plug. To easy to put together wrong. Better to find a pl259 plug that gets soldered. YouTube must have a video on it somewhere.
rrmanning06 - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 1,425
