跳转到主内容
Clothing Ribbon Button Replacement
你所需要的
  1. Clothing Ribbon Button Replacement, Ribbon Button: 步骤 1 中的图像 1,2 Clothing Ribbon Button Replacement, Ribbon Button: 步骤 1 中的图像 2,2
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: 步骤 2 中的图像 1,2 Clothing Ribbon Button Replacement: 步骤 2 中的图像 2,2
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: 步骤 3 中的图像 1,3 Clothing Ribbon Button Replacement: 步骤 3 中的图像 2,3 Clothing Ribbon Button Replacement: 步骤 3 中的图像 3,3
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: 步骤 4 中的图像 1,3 Clothing Ribbon Button Replacement: 步骤 4 中的图像 2,3 Clothing Ribbon Button Replacement: 步骤 4 中的图像 3,3
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: 步骤 5 中的图像 1,3 Clothing Ribbon Button Replacement: 步骤 5 中的图像 2,3 Clothing Ribbon Button Replacement: 步骤 5 中的图像 3,3
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: 步骤 6 中的图像 1,3 Clothing Ribbon Button Replacement: 步骤 6 中的图像 2,3 Clothing Ribbon Button Replacement: 步骤 6 中的图像 3,3
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: 步骤 7 中的图像 1,2 Clothing Ribbon Button Replacement: 步骤 7 中的图像 2,2
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: 步骤 8 中的图像 1,3 Clothing Ribbon Button Replacement: 步骤 8 中的图像 2,3 Clothing Ribbon Button Replacement: 步骤 8 中的图像 3,3
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: 步骤 9 中的图像 1,2 Clothing Ribbon Button Replacement: 步骤 9 中的图像 2,2
    • Clip any threads.
    • Admire your handiwork.
终点
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
88,782 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Community
142 名成员
创作了16,238篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 2,717
