跳转到主内容
Cloth Face Mask Nose Bridge Replacement
你所需要的
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 步骤 1 中的图像 1,2 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 步骤 1 中的图像 2,2
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: 步骤 2 中的图像 1,2 Cloth Face Mask Nose Bridge Replacement: 步骤 2 中的图像 2,2
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: 步骤 3 中的图像 1,1
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: 步骤 4 中的图像 1,2 Cloth Face Mask Nose Bridge Replacement: 步骤 4 中的图像 2,2
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: 步骤 5 中的图像 1,1
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: 步骤 6 中的图像 1,1
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
终点
另外一个人完成了本指南。
Kayla Vargas
于02/23/21注册
157 声望
撰写一个指南
团队
Texas Tech, Team S3-G15, Cowan Spring 2021 Texas Tech, Team S3-G15, Cowan Spring 2021 的会员
TTU-COWAN-S21S3G15
1 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 875
