简介
This guide shows how to close the earbuds again.
As the adhesives used set rather quickly it is recommended to read the whole guide first!
你所需要的
Clip the two halfs together to check that there isn't any old glue or wires in the way.
There should be absolutely no seam if you press them together slightly
Separate them again before continuing with the assembly.
The cover over one of the mics likes to come of. Make sure it's in the right place before going on with closing the earbuds.
While it is possible to apply glue while holding the top half it's recommended to put the top half on a stick (or scalpel) with some sticky puddy.
As the original adhesive for the pins is a flexible one it is recommended to use something similar like B7000 for them.
This makes future disassembly easier if needed.
Super glue can be used as well if this is not of concern or a fitting adhesive isn't available.
Put down a thin bead of super glue in the groove of the seam.
Align the two half before quickly pressing them together.
Use a bit of pressure to make sure the seam is fully closed and hold it for 15s to get the glue time to set.
