跳转到主内容
Closing bObi's Cover Post-Repair
你所需要的
  1. Closing bObi's Cover Post-Repair, Top Cover: 步骤 1 中的图像 1,2 Closing bObi's Cover Post-Repair, Top Cover: 步骤 1 中的图像 2,2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. Closing bObi's Cover Post-Repair: 步骤 2 中的图像 1,3 Closing bObi's Cover Post-Repair: 步骤 2 中的图像 2,3 Closing bObi's Cover Post-Repair: 步骤 2 中的图像 3,3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. Closing bObi's Cover Post-Repair: 步骤 3 中的图像 1,3 Closing bObi's Cover Post-Repair: 步骤 3 中的图像 2,3 Closing bObi's Cover Post-Repair: 步骤 3 中的图像 3,3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. Closing bObi's Cover Post-Repair: 步骤 4 中的图像 1,3 Closing bObi's Cover Post-Repair: 步骤 4 中的图像 2,3 Closing bObi's Cover Post-Repair: 步骤 4 中的图像 3,3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. Closing bObi's Cover Post-Repair, Closing bObi's Cover Post-Repair: 步骤 5 中的图像 1,1
    • Attach the circuit plugs from bObi's cover back on her main board.
    • The all white plug goes to the centre of the circuit board.
    • The smaller plug connects at the side, closer to bObi's left wheel.
  6. Closing bObi's Cover Post-Repair: 步骤 6 中的图像 1,3 Closing bObi's Cover Post-Repair: 步骤 6 中的图像 2,3 Closing bObi's Cover Post-Repair: 步骤 6 中的图像 3,3
    • Lay down bObi's cover and line up the sides carefully.
    • Re-install the front wheel's screw.
    • Place the wheel back in its compartment so it points towards bObi's touch sensors. Push down to secure it on bObi.
    • Replace the dustbin contact point fastener on bObi and install its two screws.
  7. Closing bObi's Cover Post-Repair: 步骤 7 中的图像 1,2 Closing bObi's Cover Post-Repair: 步骤 7 中的图像 2,2
    • Install the four screws that were previously found under the main brushes.
    • Place the small main brush fastener overtop the screw posts on bObi and reinstall the two thin screws which hold it in place.
    • Lay the main brush attachment in the open space.
  8. Closing bObi's Cover Post-Repair: 步骤 8 中的图像 1,2 Closing bObi's Cover Post-Repair: 步骤 8 中的图像 2,2
    • Replace the corner pieces close to the dustbin and install the 2 screws securing them on bObi.
    • These corner pieces must line up correctly with the brush attachment and hold it in place.
    • Insert the dustbin before using bObi again.
结论
Follow this guide or reverse the directions of the Opening bObi guide to reassemble your device.
2等其他人完成本指南。
Chelsea
于09/24/14注册
2,278 声望
创作了31篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 223
