跳转到主内容
ClickN Kids Tablet Battery Replacement
你所需要的
  1. ClickN Kids Tablet Battery Replacement, Battery: 步骤 1 中的图像 1,1
  2. ClickN Kids Tablet Battery Replacement: 步骤 2 中的图像 1,1
    • Using the iFix it opening tool, pry battery apart from back side of tablet.
    • The battery is connected to the back side by a strong adhesive.
    • The battery may bend during this process.
    • Be careful not to allow the battery to bend any more than necessary. Battery acid leakage is possible.
    • Be careful not to damage the wires or the black tab attached to the battery.
  3. ClickN Kids Tablet Battery Replacement: 步骤 3 中的图像 1,3 ClickN Kids Tablet Battery Replacement: 步骤 3 中的图像 2,3 ClickN Kids Tablet Battery Replacement: 步骤 3 中的图像 3,3
    • Gently remove tape from the side of the battery connecting to wires and circuits.
  4. ClickN Kids Tablet Battery Replacement: 步骤 4 中的图像 1,3 ClickN Kids Tablet Battery Replacement: 步骤 4 中的图像 2,3 ClickN Kids Tablet Battery Replacement: 步骤 4 中的图像 3,3
    • Desolder wires connecting battery to motherboard, using contact points found on motherboard.
    • Have someone who is skilled in soldering to perform this step.
    • Be careful not to destroy the motherboard or other parts of device.
结论
5等其他人完成本指南。
Kevin Finney
于03/22/15注册
562 声望
创作了4篇指南
团队
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G4
3 名成员
创作了8篇指南
3指南评论
Como puedo conseguir el repuesto de mi tabletas epik
Reyshaliz - 回复
A little then moderate skill is necessary if you are somewhat mechanically inclined shouldn't be too problematic. But as far as this gentleman's directions and steps perform the task with no problems and tablet works now. Thank you Kevin Finney and three others my four-year-old daughter Hazel is happy again thanks to you.
Collins Hill
Great Smoky Mountains , TN.
Elivia Hill - 回复
I think these are great instructions for fixing this issue!
If you'd be interested in going a step further…I've been trying to find out how to safely remove the charge port! I know how to solder the replacement onto the board but I can't confirm the best way to detach the old port!?
My god daughter would appreciate another video! :)
JenBcute - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 4,998
