跳转到主内容
Cleaning the Skullcandy Mix Master DJ Adjustment Slider
你所需要的
  1. Cleaning the Skullcandy Mix Master DJ Adjustment Slider, Cleaning the Skullcandy Mix Master DJ Adjustment Slider: 步骤 1 中的图像 1,1
    • Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
  2. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: 步骤 2 中的图像 1,1
    • Rotate the headphones so that one of the speaker cups are facing you. Remove the four Phillips 3 mm screws along the headband cover.
  3. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: 步骤 3 中的图像 1,1
    • Gently remove the cover from the headband.
    • Removing the cover too fast could break the thin wire within the headband.
  4. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: 步骤 4 中的图像 1,1
    • Using a moist Q-tip or small towel, carefully wipe the inside of the headband sheath.
    • Be careful when cleaning to avoid damaging to the wire.
    • Do not use cleaning solvents. They may cause the plastic to break down.
结论
Seth Blackburn
于03/30/15注册
110 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-3, Shastany Spring 2015 UMass Dartmouth, Team 1-3, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 470
