跳转到主内容
Cleaning Logitech MX Master
你所需要的
  1. Cleaning Logitech MX Master, The Before Shot: 步骤 1 中的图像 1,1
    • That's a lot of gunk!
  2. Cleaning Logitech MX Master, Removing the Feet: 步骤 2 中的图像 1,2 Cleaning Logitech MX Master, Removing the Feet: 步骤 2 中的图像 2,2
    • The mouse has four feet on the bottom, but only the two long ones need to be removed. I used the Jimmy from the Pro Tech Toolkit.
    • I didn't have new feet on hand, so I had to reuse the original ones. This is why there's no step for cleaning the adhesive off and putting new feet on.
  3. Cleaning Logitech MX Master, Screw Time!: 步骤 3 中的图像 1,3 Cleaning Logitech MX Master, Screw Time!: 步骤 3 中的图像 2,3 Cleaning Logitech MX Master, Screw Time!: 步骤 3 中的图像 3,3
    • Rev up those screwdrivers! The first wave consists of four PH1 and two T5 screws on the bottom.
    • Once those are taken care of, the mouse should be easy to pop open.
  4. Cleaning Logitech MX Master, Popping it Open: 步骤 4 中的图像 1,2 Cleaning Logitech MX Master, Popping it Open: 步骤 4 中的图像 2,2
    • When opening the mouse take into account the position of the clamps so you won't pop more than you want.
  5. Cleaning Logitech MX Master, Ribbon cables.: 步骤 5 中的图像 1,1
    • Pop the connector open with whatever tool you find works best, unless you're like me and accidentally pulled the cable out of the connector in the previous step.
  6. Cleaning Logitech MX Master, Bottom Half: 步骤 6 中的图像 1,3 Cleaning Logitech MX Master, Bottom Half: 步骤 6 中的图像 2,3 Cleaning Logitech MX Master, Bottom Half: 步骤 6 中的图像 3,3
    • This is the part where I realize I need better lighting.
    • Set the top half aside for now. Removal of the battery consists of three PH1 screws and one connector that really doesn't want to come loose.
  7. Cleaning Logitech MX Master, Bottom Half (continued): 步骤 7 中的图像 1,3 Cleaning Logitech MX Master, Bottom Half (continued): 步骤 7 中的图像 2,3 Cleaning Logitech MX Master, Bottom Half (continued): 步骤 7 中的图像 3,3
    • Time for a bit change! The PCB housing the switches for left and right clicks comes off with four P0 screws and another ZIF connector.
    • The scroll wheel assembly is held in with two P0 screws at the front. There's also a connector for the motor hiding under the ribbon cable for the PCB you just removed.
    • These screws aren't visible in this step, but can be seen in the previous one. I'm terrible at taking pictures.
    • You can see some of the debris causing my scrolling issues in the last photo.
  8. Cleaning Logitech MX Master, Bottom PCB: 步骤 8 中的图像 1,2 Cleaning Logitech MX Master, Bottom PCB: 步骤 8 中的图像 2,2
    • Three more P0 screws hold this one in place.
    • Be careful to put the little doohickey on the red wire back in place (I can't remember the name)
    • We can see the micro USB connector on the underside. Unfortunately, I can't upgrade it to USB-C with the equipment I have.
    • I have the equipment to clean it though! A can of compressed air was all I needed.
  9. Cleaning Logitech MX Master, Scroll Wheel: 步骤 9 中的图像 1,3 Cleaning Logitech MX Master, Scroll Wheel: 步骤 9 中的图像 2,3 Cleaning Logitech MX Master, Scroll Wheel: 步骤 9 中的图像 3,3
    • I couldn't get the wheel out of the assembly, but I was able to spin it with some compressed air. I didn't get it on video, but a big chunk of dust came flying out.
    • I apologize in advance for filming in portrait mode. Also, I failed to get a shot of the debris inside the wheel.
    • That spring on the bottom in the first picture will probably fall off. Make sure to keep track of it.
    • I took the assembly apart in an effort to get the wheel out - no dice. I don't know where this oddly shaped spring goes, possibly on this peg, but I left it out and it doesn't seem to be important.
  10. Cleaning Logitech MX Master, Almost Done!: 步骤 10 中的图像 1,2 Cleaning Logitech MX Master, Almost Done!: 步骤 10 中的图像 2,2
    • You can follow steps 5-8 in reverse in order to put the bottom back together.
    • The top just needs a bit of compressed air, no disassembly required.
    • You can press the buttons down to gain easier access to the debris.
  11. Cleaning Logitech MX Master, Congratulations, you did it!: 步骤 11 中的图像 1,1
    • After following steps 1-4 in reverse, your mouse is clean again! And probably cleaner than mine.
结论
Insert conclusion here?
35等其他人完成本指南。
Skylar
于01/22/15注册
1,145 声望
撰写一个指南
团队
Donut Donut 的会员
Business
1 名成员
创作了5篇指南
17指南评论
I followed your guide and I found a problem when I put everything together again. Now I turn on the mouse and it’s broken. The battery leds just blink and it doesn’t respond to pressing the channel selection or connect buttons, it just doesn’t work or sincronizes with the dongle, just shows the battery leds blinking. Anyone has any suggestion? Many thanks.
Juan Suarez - 回复
I have the same problem (all three LED’s blink green and no response to pressing channel selection or connect buttons) that Juan Suarez describes.
I would also be happy for any suggestions on how to fix the issue.
Max -
And? Did you find a way to fix it?
Nicholas Blair -
Unfortunately I did not.
Max -
Have you tried reseating the ribbon cables?
Skylar -
添加评论
浏览统计数据:
过去 24 小时: 36
过去 7 天: 258
过去 30 天: 1,163
总计 111,971
