跳转到主内容
Cleaning Debris from Flywheel Screen
你所需要的
  1. Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: 步骤 1 中的图像 1,3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: 步骤 1 中的图像 2,3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: 步骤 1 中的图像 3,3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning Debris from Flywheel Screen: 步骤 2 中的图像 1,2 Cleaning Debris from Flywheel Screen: 步骤 2 中的图像 2,2
    • Using compressed air or a rag, clean debris from the flywheel.
结论
2等其他人完成本指南。
Ethan Narad
于04/19/18注册
529 声望
创作了3篇指南
团队
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G15
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 29
过去 30 天: 34
总计 1,161
