当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Firstly Disconnect battery
Always take the negative terminal off first.
'''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
Locate throttle linkage cable assembly.
Twist the assembly clockwise.
Slide both slackened cables off assembly’s guides.
Locate the two hoses on the top of the throttle body.
Gently lift the hoses off.
Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
Remove the intake tube from the throttle body.
Locate wiring clip on the underside of the throttle body.
Press down on the locking mechanism before gently removing the wiring clip.
Locate throttle linkage arm.
Open the locking clip with a flat head screwdriver.
Pry off the linkage arm with a flat head screwdriver.
Locate the three 13mm nuts attaching the throttle body to the intake manifold.
Remove nuts with a 13mm crescent wrench.
Lift the throttle body off of the intake manifold.
The manifold is now out of the engine bay and ready for cleaning or adjustment.
Cover the electrical contacts with a shop towel to prevent throttle body cleaner from inadvertently spilling over.
Liberally apply throttle body cleaner to the inside of throttle body and butterfly valve.
Use a shop towel sprayed with cleaner to wipe off thick grime if severely dirtied.
Spray electrical cleaner on the metal contacts to blast away particles in the bracket.
Spray off the wiring clip that attaches to the throttle body inside the engine bay.
Apply a small amount of dielectric grease to the metal contacts to prevent corrosion.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于10/11/10注册
76 声望
创作了2篇指南
徽章: 8
+ 5更多徽章
CPSU-REGAN-F10S3G28
4 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 24
总计 8,014
