简介
Follow this guide to replace the lower drive chain on a 2018 Classen Sod Cutter model HSC18AHD.
你所需要的
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
步骤 8 Remove the chain guard
注意:步骤 8-10 源自标记为进行中的 指南。
Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
Use a marker to mark the locations for each bearing before disassembly.
即将完成!
结论
另外一个人完成了本指南。
