跳转到主内容
Clarke Floor Sander 07012A 2012 Control Switch Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    Clarke Floor Sander 07012A 2012 Control Switch Replacement, Disconnect all power cables: 步骤 1 中的图像 1,1
    • Before you begin your repair, disconnect all power cables to reduce the risk of short circuits and electric shock.
  2. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the dust bag: 步骤 2 中的图像 1,2 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the dust bag: 步骤 2 中的图像 2,2
    • Pull on the dust bag to remove it from the dust tube.
    • If the dust bag doesn't slide off easily, gently twist it back and forth while pulling to free it from the tube.
  3. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the dust tube: 步骤 3 中的图像 1,1
    • Pull up on the dust tube to remove it from the sander.
  4. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Disconnect the control link arm: 步骤 4 中的图像 1,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Disconnect the control link arm: 步骤 4 中的图像 2,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Disconnect the control link arm: 步骤 4 中的图像 3,3
    • Slide the collar on the control link arm up until the two halves of the arm detach from one another.
  5. Clarke Floor Sander 07012A 2012 Control Switch Replacement: 步骤 5 中的图像 1,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement: 步骤 5 中的图像 2,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement: 步骤 5 中的图像 3,3
    • Pull up on the latch at the bottom of the handle assembly, then remove the retaining plate from its slot in the handle.
  6. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the handle: 步骤 6 中的图像 1,2 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the handle: 步骤 6 中的图像 2,2
    • Pull up on the handle assembly and remove it from the sander.
  7. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Loosen the nut around the control switch: 步骤 7 中的图像 1,2 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Loosen the nut around the control switch: 步骤 7 中的图像 2,2
    • Use a socket wrench with a deep 9/16" socket to remove the retaining nut and star washer from the control switch toggle.
  8. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the control housing screws: 步骤 8 中的图像 1,2 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the control housing screws: 步骤 8 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the six screws on the control housing—three on either side.
  9. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Open the control housing: 步骤 9 中的图像 1,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Open the control housing: 步骤 9 中的图像 2,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Open the control housing: 步骤 9 中的图像 3,3
    • Lift the control housing up and swing it open so the wiring panel inside is accessible.
    • The housing is still attached to the handle tube, do not try to pull it away completely.
  10. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Disconnect the control switch terminals: 步骤 10 中的图像 1,1
    • Before disassembly, note where each lead connects. Be sure to return each one to its original position in the wiring panel during reassembly.
    • Use a #2 Phillips head screwdriver to remove the following three screws from the wiring panel:
    • Two 10-32 x 3/8" screws
    • One 8-32 x 3/8" screw
    • Remove the ring and fork terminals from the screws.
  11. Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the control switch: 步骤 11 中的图像 1,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the control switch: 步骤 11 中的图像 2,3 Clarke Floor Sander 07012A 2012 Control Switch Replacement, Remove the control switch: 步骤 11 中的图像 3,3
    • Pull and gently wiggle the control switch to remove it from its mounting hole in the control housing.
    • There may be an additional star washer on the toggle switch inside the housing. Remove and retain it for reassembly.
结论
9等其他人完成本指南。
Tarun Thiruma
于11/20/19注册
35,271 声望
创作了134篇指南
2条评论
Well Done, steps are clear and EZ 8 to follow!
Jack Warner - 回复
Thank you excellent instruction
davefriedmanguitarist - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 74
总计 3,696
