跳转到主内容
加入维修社区 - 创建账户
Clarinet Cork Replacement
你所需要的
  1. Clarinet Cork Replacement, Cork: 步骤 1 中的图像 1,1
    • Using pliers, remove the old cork by pinching it off.
    • Make sure not to push too hard with the pliers, as you can crack or chip the structure.
  2. Clarinet Cork Replacement: 步骤 2 中的图像 1,1
    • Clean the joint with soap and water
  3. Clarinet Cork Replacement: 步骤 3 中的图像 1,1
    • Measure the width of the tenon joint.
    • Only measure the area where the cork will lie, not the entire joint.
  4. Clarinet Cork Replacement: 步骤 4 中的图像 1,1
    • Cut the new cork to match the width of the tenon joint.
  5. Clarinet Cork Replacement: 步骤 5 中的图像 1,1
    • Peel off the backside of the cork to reveal the adhesive.
  6. Clarinet Cork Replacement: 步骤 6 中的图像 1,1
    • Wrap the cork around the joint.
  7. Clarinet Cork Replacement: 步骤 7 中的图像 1,1
    • Sand the cork with sandpaper until the cork is smooth.
  8. Clarinet Cork Replacement: 步骤 8 中的图像 1,1
    • Apply cork grease on the new cork.
  9. Clarinet Cork Replacement: 步骤 9 中的图像 1,1
    • Slowly twist and slide the joint back together.
结论
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
9等其他人完成本指南。
Hill Xiong
于10/26/17注册
306 声望
撰写一个指南
团队
4指南评论
Where do you buy the corks from? Could you post a link to them?
Joshua Leung - 回复
Make sure to use sandpaper with around 60 - 80 grit
[deleted] - 回复
Wat if the cork strips don't have adhesive.wat do I use
kendall mckenzie - 回复
Contact cement. See this article.
David Willett -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 113
总计 15,888
