跳转到主内容
加入维修社区 - 创建账户
Citizen Promaster Dive Automatic Strap Replacement
你所需要的
  1. Citizen Promaster Dive Automatic Strap Replacement, Strap: 步骤 1 中的图像 1,3 Citizen Promaster Dive Automatic Strap Replacement, Strap: 步骤 1 中的图像 2,3 Citizen Promaster Dive Automatic Strap Replacement, Strap: 步骤 1 中的图像 3,3
    • Flip your watch to the back.
    • Insert the small end with the bar between the fork. Press outwards; when you feel the pressure, pull up slowly.
  2. Citizen Promaster Dive Automatic Strap Replacement: 步骤 2 中的图像 1,3 Citizen Promaster Dive Automatic Strap Replacement: 步骤 2 中的图像 2,3 Citizen Promaster Dive Automatic Strap Replacement: 步骤 2 中的图像 3,3
    • When the bar pops out, pull the strap out.
    • Remove the bar from the strap and place the spring bar in the new strap.
  3. Citizen Promaster Dive Automatic Strap Replacement: 步骤 3 中的图像 1,2 Citizen Promaster Dive Automatic Strap Replacement: 步骤 3 中的图像 2,2
    • Insert one end of the spring bar into one of the holes and hold it in place.
  4. Citizen Promaster Dive Automatic Strap Replacement: 步骤 4 中的图像 1,2 Citizen Promaster Dive Automatic Strap Replacement: 步骤 4 中的图像 2,2
    • With the larger end press the bar in.
    • Guide to the hole.
结论
Replace the other strap by following the same instructions.
另外一个人完成了本指南。
Ismael Vega
于11/28/23注册
133 声望
撰写一个指南
1指南评论
After the automatic watch fell to the ground, the back glass was broken and it stopped working
Zerihun Denu - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 104
总计 1,518
