跳转到主内容
Citizen Men's Watch 1102 Series Hands Replacement
你所需要的
  1. Citizen Men's Watch 1102 Series Hands Replacement, Watch Face Hands: 步骤 1 中的图像 1,1
    • Locate the notch under the back cap of the watch. Wedge the jimmy into the notch, and pry off the back.
  2. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 2 中的图像 1,1
    • Remove the circular plastic cover from inside the watch.
  3. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 3 中的图像 1,1
    • Remove the crown stalk by placing the needle in the release notch. This will release stalk and allow it to slide out.
  4. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 4 中的图像 1,1
    • Turn watch on its side and let the watch face fall out.
  5. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently pry the watch hands off of the face of the watch with the jimmy and tweezers.
  6. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers to replace the hands of the watch.
    • First, place the hour hand on the watch face stem, followed by the minute hand, and the second hand.
  7. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 7 中的图像 1,1
    • Place the watch face downwards in its case.
    • Make sure the crown stalk holes are aligned.
  8. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 8 中的图像 1,1
    • Insert the crown stalk into the crown stalk holes.
  9. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 9 中的图像 1,1
    • Place the plastic cover back in its original place.
    • Use the crown notch for guidance in alignment.
  10. Citizen Men's Watch 1102 Series Hands Replacement: 步骤 10 中的图像 1,1
    • Press the back cover on the watch using hands or clamp, until it pops into place.
结论
Now that the watch hands are repaired, the watch can be reset manually so that the it can keep the correct time.
Justin Sidwell
于02/28/17注册
111 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 39
总计 3,554
