跳转到主内容
Cisco Meraki MC74-HW Sensor Cover Replacement
你所需要的
  1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: 步骤 1 中的图像 1,3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: 步骤 1 中的图像 2,3 Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: 步骤 1 中的图像 3,3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 2 中的图像 1,2 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 2 中的图像 2,2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 3 中的图像 1,3 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 3 中的图像 2,3 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 4 中的图像 1,2 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 4 中的图像 2,2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: 步骤 5 中的图像 1,2 Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 6 中的图像 1,3 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 6 中的图像 2,3 Cisco Meraki MC74-HW Sensor Cover Replacement: 步骤 6 中的图像 3,3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
  7. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: 步骤 7 中的图像 1,3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: 步骤 7 中的图像 2,3 Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: 步骤 7 中的图像 3,3
    • Remove the two 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the sensor cover.
结论
Anthony Kairouz
于10/18/21注册
253 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-5, Simcock Fall 2021 UMass Dartmouth, Team 1-5, Simcock Fall 2021 的会员
UMASSD-SIMCOCK-F21S1G5
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 216
