跳转到主内容
简介
Disassembly guide for Cisco Aironet 1242ag Access Point
工具
配件
没有特定配件。
  1. The equipment cover is held by 4 screws. The equipment cover is held by 4 screws.
    • The equipment cover is held by 4 screws.
  2. Once the 4 screws are removed, push to the side to remove the cover.
    • Once the 4 screws are removed, push to the side to remove the cover.
  3. The card is attached to the bottom plate by 4 screws Before removing the logic board, disconnect the antenna cables in both parts of the device. There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
    • The card is attached to the bottom plate by 4 screws
    • Before removing the logic board, disconnect the antenna cables in both parts of the device.
    • There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
  4. Write the wisdom here. Write the wisdom here. Write the wisdom here.
    • Write the wisdom here.
结论
另外一个人完成了本指南。
特别感谢这些译者︰
es en
91%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
附加文件
Eneider Colina
于2013年09月20日注册
2,297 信誉积分
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 2
过去的30天: 7
总计 547
