跳转到主内容
Cisco 878 Integrated Services Router Inner Metal Shield Disassembly
你所需要的
  1. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 步骤 1 中的图像 1,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 步骤 1 中的图像 2,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 步骤 1 中的图像 3,3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 步骤 2 中的图像 1,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 步骤 2 中的图像 2,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 步骤 2 中的图像 3,3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the three screws on front side: 步骤 3 中的图像 1,2 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the three screws on front side: 步骤 3 中的图像 2,2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 步骤 4 中的图像 1,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 步骤 4 中的图像 2,3 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 步骤 4 中的图像 3,3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
结论
另外一个人完成了本指南。
Jiri Altman
于05/03/16注册
1,521 声望
创作了9篇指南
团队
4k20 Repair Team 4k20 Repair Team 的会员
Community
2 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 212
