跳转到主内容
Circuit Board Housing Removal
你所需要的
  1. Circuit Board Housing Removal, Battery: 步骤 1 中的图像 1,2 Circuit Board Housing Removal, Battery: 步骤 1 中的图像 2,2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: 步骤 2 中的图像 1,2 Circuit Board Housing Removal: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: 步骤 3 中的图像 1,3 Circuit Board Housing Removal, Circuit Board Housing: 步骤 3 中的图像 2,3 Circuit Board Housing Removal, Circuit Board Housing: 步骤 3 中的图像 3,3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: 步骤 4 中的图像 1,2 Circuit Board Housing Removal: 步骤 4 中的图像 2,2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: 步骤 5 中的图像 1,2 Circuit Board Housing Removal: 步骤 5 中的图像 2,2
    • Remove the back cover completely from the phone.
结论
Jonathan Flowers
于10/18/13注册
607 声望
创作了6篇指南
团队
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G7
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 14
总计 611
