跳转到主内容
Cirago M9030 Motherboard Replacement
你所需要的
  1. Cirago M9030 Motherboard Replacement, Cover: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Motherboard Replacement: 步骤 3 中的图像 1,2 Cirago M9030 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Motherboard Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Motherboard Replacement: 步骤 5 中的图像 1,3 Cirago M9030 Motherboard Replacement: 步骤 5 中的图像 2,3 Cirago M9030 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Motherboard Replacement: 步骤 6 中的图像 1,3 Cirago M9030 Motherboard Replacement: 步骤 6 中的图像 2,3 Cirago M9030 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Motherboard Replacement, IDE Connector: 步骤 7 中的图像 1,2 Cirago M9030 Motherboard Replacement, IDE Connector: 步骤 7 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Motherboard Replacement: 步骤 9 中的图像 1,2 Cirago M9030 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Motherboard Replacement: 步骤 11 中的图像 1,2 Cirago M9030 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 Cirago M9030 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
结论
Ryan Sutardji
于06/29/12注册
171 声望
创作了7篇指南
团队
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,003
