跳转到主内容
Cirago M9030 Cover Replacement
你所需要的
  1. Cirago M9030 Cover Replacement, Cover: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Cover Replacement: 步骤 2 中的图像 1,1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Cover Replacement: 步骤 3 中的图像 1,2 Cirago M9030 Cover Replacement: 步骤 3 中的图像 2,2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
结论
In order to reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Ryan Sutardji
于06/29/12注册
171 声望
创作了7篇指南
团队
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 879
