简介
This is a replacement guide for the Cirago M9030 Cover. The following steps will guide you in the dismantling and rebuilding of the cover as well as a replacement.
你所需要的
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
即将完成!
In order to reassemble your device, follow these instructions in reverse order.
结论
另外一个人完成了本指南。
